Page 11 of 12 FirstFirst ... 6789101112 LastLast
Results 101 to 110 of 111
Thread: Paint and airbrushing tips and advice
  1. #101
    2nd May 2009
    I've seen American sites refer to Future Floor Polish but I haven't found any in WA. I use Tamiya's flat clear spray for my work.
    I don't know if it adds protection but it 'levels out' the differing shininess of the paints used and generally makes them look nicer. Plus it can take some of the stickiness away.
    I get mine from hobby shops. I have seen Bunnings stock gloss and semi-gloss clear sprays but haven't tried them.
    Hope that helps.
  2. #102
    7th Oct 2015
    A top coat is definitely advisable if you want to protect your paintwork, just use Tamiya clear coat, matte and/or gloss. It comes in a spray can for quick and easy application.
  3. #103
    26th May 2009
    Something I saw in a video that I've tried is flushing my airbrush with warm water between colorvswaos, it seems to help clean it out a bit better than cold water
  4. #104
    23rd Feb 2022
    Cairns
    Quote Originally Posted by snaketales View Post
    Hope that helps.
    Quote Originally Posted by Ralph Wiggum View Post
    Thanks for the advice. Will look into getting Tamiya brand coats.
  5. #105
    15th Aug 2014
    Aldi has their airbrush kit in the new catalogue. I have one of these and it is really good.
    https://www.aldi.com.au/en/special-b...pressor-kit-3/
  6. #106
    15th Aug 2014
    The Aldi kit has the filter but no tank. Bunnings has the Ozito version of the kit with the tank but I don't think the filter for around the same price on special.
  7. #107
    I just bought one for the filter. Runs ok, small cheap compressor.
  8. #108
    7th Mar 2012
    The Moon
    A year or 2 ago my brother gave me his airbrush kit. He told me the needle needs replacing but doesn’t remember what size as it’s been years since he used it. It’s an Iwata HP-C Plus. Can anyone point me in the direction of a replacement needle for it? Not knowing the lingo makes it hard to work out what I need to buy.
    Also, as I’m o my starting out with PLA+ on my printer, what should I buy to paint it with?
    Thanks.
    Dovie'andi se tovya sagain
  9. #109
    15th Aug 2014
    I think that is the same model that I have. I got a spare needle and a cleaning kit from a mob in Adelaide. I will have a look in the garage tomorrow and let you know where I got it or if not what you need to ask for.
  10. #110
    That's a nice solid airbrush. These are the parts you might need. Ideally they should be paired but if the nozzle is fine and not cracked it should be ok with just replacing the needle.
    For paint Tamiya and Vallejo acrylics are relatively safe and spray nicely.
