Results 1 to 10 of 12
Thread: Need help about Strengthening Ball Joints
    14th Oct 2009
    Default Need help about Strengthening Ball Joints
    so lately I hav been super annoyed at the loose ball joints of one of my figures (animated samurai prowl's hips), originally I thought I wouldnt care, but just yesterday wen I tried to pose him differently he kept doing da splits, so I just chucked him in a sitting position
    anyway enough with da rubbish, so I was searching da internet and everything, I hav some questions about strengthening ball joints
    1) ppl hav been saying use either nail polish or super glue, which one is better (or u prefer) and which one is easier? I dont hav much experience with modding/fixing/touching up my tfs
    2) I've heard da disadvantages of nail polish is dat it wears and peels off eventually with play, and wen it peels, it peels some of da underlying plastic as well, is dis tru? as I do play with my toys and transform them regularly
    3)With super glue I heard dat it may leave chalky white residue or wateva on the plastic if not done carefully, wat is the bad thing about dis?
    4) and finally, if using superglue, do you guys pop the ball joint off and apply it, or u just drip some onto the joint and then rapidly move the joint until the superglue dries
    I dont hav spare tfs or any tfs dat I dont care about if I stuff up, so I wanna do it rite the first time
    thanks! (long post I kno, I apologise for dat)
    1) I have never used Polish but it would be better than Superglue given that it is completely clear - Just don't over do it, a thin coat should do.
    2) I can't say that wear of Nailpolish is true because I haven't used it but I can say that when you use superglue, it is permanent - However Super glue is only good for inner hidden parts, never use it in exposed areas as it doesn't dry clear.
    3)It is not just chalky as in dust, it is stuck on the plastic, it's what causes the friction and why you should never use it in areas that you can see form the outside.
    4) I pop off the ball joint, coat it and then plug it back in and spin it very quickly so that the superglue dries in the shape of the socket. This is risky because if you don't continue to spin it until its fully dry, the joint may remain fixed forever which is bad.
    4th Aug 2008
    The 'Riff
    I think my missus has some clear nail polish, so I will test it out. One of the missile launchers for my Henkei Thundercracker sits really loose inside his arm, and even in jet mode. I will clear coat the peg to bulk it up and see what happens. Though because it is really loose (as in even if I breathe on him) it will fall out.
    2nd May 2009
    I have found clear nail polish good for strengthening ball joints. I've used it only in the past few months so I can't say if there are any negative long-term effects.
    I also don't transform my figures a lot but I would guess that repeated transformations over a length of time may wear nail polish layers down.
    The nail polish I use stinks a bit so any figures I use it on are left out to air before going in the display cabinet.
    I prefer using nail polish than super glue because the effects are worse if you stuff up super glue (I have glued my fingers to more than one figure )
    31st Dec 2007
    Western Sydney
    I've used clear nail polish on a couple of ball joints with no issues.
    Trick is to use light coats, coating the entire joint quickly, leaving for 10 or more minutes, testing the joint to see if it is tighter, then repeating until satisfied.
    17th Jan 2008
    Baldivis
    I use superglue regularly to tighten ball joints, normal joints, accessory posts, points of rotation, etc.
    I use a brand from bunnings and it doesnt leave any of that white residue.
    Use it sparringly though - drop on a small amount to the ball or cup or one of the joint surfaces. let is spread itself (its pretty runny) and dry. Test fit. Do again if need be. Works a treat!
    TF Figs of 2023:
    1) WnR Springer
    2) Legacy Bludgeon
    3) Legacy Leo Prime/Nemesis Leo Prime.
    14th Oct 2009
    thanks kup, 1AZRAEL1, snaketales, i_amtrunks and klystron on ur tips experiences! It has been very very helpful. I guess I shall try nail polish first as it doesnt seem to be as dangerous and easier to apply, thanks again!
    "sometimes the things you see might not be real and the things that are real you might not see"
    28th Feb 2009
    Katoomba
    I've also heard using 3M scotch tape for ball joints as a fix.
    4th Aug 2008
    The 'Riff
    I have used clear nail polish on fixing up loose action masters, and it works pretty well. Like if the arms are loose or legs flimsy. So far so good. The legs for Sideswipe were really loose (and until I had opened him up) realised the rubber loop was missing. Will replace with a small elastic band when I get some.
    But as for the nail polish, it works well, easy enough to use, just make sure if you need to bulk it up quite a bit, do it layer by layer and don't put it on too thick. Let it dry and do another coat until it is more sturdy.
    10th Apr 2010
    so what worked best for you? Supaglue or nail polish? I am worried that the arm or leg will get stuck......
