Originally Posted by
GoktimusPrime
Couldn't they make the sword out of harder plastic? (i.e. some plastic quality as the fists themselves) -- that would solve the problem of denting on the handles.
if you made the sword in the same hard rigid plastic... I think it would break more easily. I had the sword in his hip sheath, and after I accidentally banged my shelf, he fell down with quite a bang, I figured, luckily his sword is soft plastic otherwise that fall would have snapped his sword... I'd rather a bent sword (and one that has dents) than a broken sword, since the blade part is pretty thin and long, perfect for snapping
on another note, does anyone think holding the small dagger would be dangerous as well? Because although handle is smaller/thinner, he does hold it pretty tight as well
"sometimes the things you see might not be real and the things that are real you might not see"
